MC_Florida Posted April 19, 2017 Share Posted April 19, 2017 Hello all ....... can anyone help me or please point me in the right direction. I need to put 1x4 furring strips at 16" o.c. on the bottom of the trusses to fur down the drywall to match an existing ceiling height completed in the same manner. I'm using x8 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 19, 2017 Share Posted April 19, 2017 Depending on the complexity of the plan you might just draw some psolids in elevation view and extend them in floor plan. Draw cross boxes in your section layout view. If you need more help send me a PM. Link to comment Share on other sites More sharing options...
DavidJames Posted April 19, 2017 Share Posted April 19, 2017 I'd just use general framing and then adjust the ceiling structure: Link to comment Share on other sites More sharing options...
Chopsaw Posted April 19, 2017 Share Posted April 19, 2017 Yes the general framing is faster and provides an automatic cross box if your ceiling is flat. Link to comment Share on other sites More sharing options...
MC_Florida Posted April 19, 2017 Author Share Posted April 19, 2017 OK the general framing is working I just need to get through the ceiling structure adjustment. its lifting above the block walls. guess I need to play with the numbers some more. Thank you for the guidance Link to comment Share on other sites More sharing options...
Chopsaw Posted April 19, 2017 Share Posted April 19, 2017 Just add a "Insulation Air Gap" layer to the Ceiling finish (J) layer above the drywall in the Room Specification DBX on the Structure tab. Link to comment Share on other sites More sharing options...
