X9 cabinet mounted outlets
steve_stuart
Just to clarify, you should probably not use the "cabinet mounted" electrical symbols from older versions of the library anymore.  These were really just floor mounted symbols that were turned vertical so you could bump them up against cabinets.  They never really worked that well so we got rid of them.  In X9, all wall mounted electrical objects can be attached to cabinet sides the same as they are attached to walls.  Also, you can move them from walls to cabinets or vice versa.
