steve_stuart Posted April 17, 2017 Share Posted April 17, 2017 Are the cabinet mounted outlets gone in X9? I can't find them in the library where they were in X8; are they somewhere else or have they been removed? I use these all the time, very disappointed if they are gone... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 17, 2017 Share Posted April 17, 2017 Normal electrical items can be mounted directly to cabinets in X9. No need for the extra library anymore. Link to comment Share on other sites More sharing options...
steve_stuart Posted April 17, 2017 Author Share Posted April 17, 2017 thank you Link to comment Share on other sites More sharing options...
Dermot Posted April 17, 2017 Share Posted April 17, 2017 Just to clarify, you should probably not use the "cabinet mounted" electrical symbols from older versions of the library anymore. These were really just floor mounted symbols that were turned vertical so you could bump them up against cabinets. They never really worked that well so we got rid of them. In X9, all wall mounted electrical objects can be attached to cabinet sides the same as they are attached to walls. Also, you can move them from walls to cabinets or vice versa. Link to comment Share on other sites More sharing options...
