Reference Set - Show roof "FILL"
SNestor
Is there a layer of setting that can be turned on to allow the roof fill pattern to show via a REF SET?
Basically...I have a two story home...roof planes on both the 1st floor level and 2nd floor level.  I'd like to show the roof fill pattern in the roofs that are on the 1st floor level.  I know I can move the lower level roofs "UP"...then I wouldn't need a "REF SET" to see the roof planes...but, is there a way to achieve the same without moving the roof planes?
Thanks...
Here's a pic...
11 minutes ago, dshall said:
Yes,  see pic,  however I think there is more of a downside than an upside to using this but I forgot the reason.
58e3ea19b0d95_ScreenShot2017-04-04at11_45_02AM.thumb.png.1ee6af415d4c243728704074d4bede8a.png
Scott...that did the trick.  Thanks.
Actually...I'm not sure I want to do this anyway...but, just wondered if it was possible...and if so, how to make it happen.
I did have to change "Display Options" to "Draw Reference Floor First"...in order to get the 2nd floor roof to sit on top of the lower roof plane.  Not sure why...but it works
