Jones_Drafting Posted March 16, 2017 Share Posted March 16, 2017 Problem, After printing to pdf w/ pdf995 print driver, I reviewed the plan set. Strange varying line weight, half-way through elevation, or plan views, the line weight shifts...... Thought it was something having to do with print driver, so upgraded to most recent. (No change) I've got quite a number of active line drawings sent to layout. Is it just too much for chief? Has anyone else experienced/found a fix, for this? Thanks in advance, Cris Link to comment Share on other sites More sharing options...
Chopsaw Posted March 16, 2017 Share Posted March 16, 2017 Have you tried the "Chief Architect Save As PDF" to see if the results are the same? It usually gives me the best results. However there is still an issue that they are working on but not sure if it is the same as what you are experiencing. Could you post a sample? Link to comment Share on other sites More sharing options...
Jones_Drafting Posted March 16, 2017 Author Share Posted March 16, 2017 10 minutes ago, Chopsaw said: Have you tried the "Chief Architect Save As PDF" to see if the results are the same? It usually gives me the best results. However there is still an issue that they are working on but not sure if it is the same as what you are experiencing. Could you post a sample? Trying out the "save as pdf" option....will let you know. Thanks! Link to comment Share on other sites More sharing options...
Jones_Drafting Posted March 16, 2017 Author Share Posted March 16, 2017 6 minutes ago, Jones_Drafting said: 18 minutes ago, Chopsaw said: Have you tried the "Chief Architect Save As PDF" to see if the results are the same? It usually gives me the best results. However there is still an issue that they are working on but not sure if it is the same as what you are experiencing. Could you post a sample? Did it! Thanks! Link to comment Share on other sites More sharing options...
