sdpatt Posted March 5, 2017 Share Posted March 5, 2017 I am working in a massive drawing with many buildings. I have accidentally hit the Automatic Exterior dimention Key which dimentioned each building. Is there a way to "back out" of this in lieu manually removing the dimentions from every building? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 5, 2017 Share Posted March 5, 2017 A few Options.... 1. Hit Undo 2. Edit>Delete Objects. Select "All Rooms On This Floor", check Automatic Dimensions, and click Delete. 3. Select one of the automatic dimensions, click on the Match Properties tool (Control+J), check "Layer", click Okay, and then hit delete. 4. If you want to be a little more selective, activate one of the manual dimension tools and Shift (or Control) select the desired dimensions (either with a marquis or one by one). It may help to turn off some layers for this operation depending on what exactly you're trying to do. Link to comment Share on other sites More sharing options...
lbuttery Posted March 5, 2017 Share Posted March 5, 2017 This may be a case where each building is done in a separate plan then saved as a 3D symbol and stored in the library then in the master site plan add all those symbols this is not required but is how I like to handle projects with multiple buildings it also allows for building roofs and framing etc independently Lew Link to comment Share on other sites More sharing options...
