dacorn Posted June 22, 2014 Share Posted June 22, 2014 Hi All, I am creating a stacked gable on a 20 foot wall, thus I have to create that manually, no big deal, however I want to have a different surface on the wall than the rest of the house. No problem to change the wall by cutting the wall, however I can not get the surface to change on the attic wall under my stacked gable. Secondly I want to create the gable return on the stacked gable, the auto return setting will not add the return to the stacked gable. I am sure I am looking too deep into both issues, if someone can help that would be greatly appreciated. Regards, Dave Acorn Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 23, 2014 Share Posted June 23, 2014 select the attic wall in plan or a camera view then go that wall's dialog box-materials tab and change the material for the exterior wall layer of it. In plan view you toggle up to the <A> level to select attic walls, or just in any camera view select the wall, then open it'd dialog box. DJP Link to comment Share on other sites More sharing options...
dacorn Posted June 23, 2014 Author Share Posted June 23, 2014 Hi David, Yes I tried that however it changes the material for the entire gable, I only want to change the material on the stacked gable. In my photo I want the grey to be only on the same section not then entire gable. Thanks very much for your assistance. Regards, Dave Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted June 23, 2014 Share Posted June 23, 2014 1.Sometimes CA won't build a auto return for whatever reason. Just build it manually. I usually always build mine manually. By doing that I have the option to give the return a different pitch than the rest of the roof. 2. Put the stacked gable on it's own layer and then changed the material. Link to comment Share on other sites More sharing options...
dacorn Posted June 23, 2014 Author Share Posted June 23, 2014 Hi Larry Thanks for the response, yes I think its best I will just make the returns manually, I like the idea of changing the pitch, thanks for that. For the stacked gable I did move this to its own layer but that didn't seem to change the ability to change the exterior wall material on the stacked gable. I may be missing something here I think. I didn't join the roof planes on the stacked gable, but I wasn't sure if that was requited. It is like Chief doesn't know the stacked gable exists as it only allows me to change the material on the entire gable, or only on the part of the wall I cut on the attic wall. Perhaps if you can walk me through this that would allow me to see the entire picture. Thanks in advance! Regards, Dave Link to comment Share on other sites More sharing options...
Solution Larry_Sweeney Posted June 24, 2014 Solution Share Posted June 24, 2014 The easiest solution to your problem is to post the plan. Link to comment Share on other sites More sharing options...
