renom3 Posted March 1, 2017 Share Posted March 1, 2017 There is a way to see in plan view how looks (in size and shape) the 3d molding polyline like it look in camera view ? Link to comment Share on other sites More sharing options...
rlackore Posted March 1, 2017 Share Posted March 1, 2017 I don't believe so. Link to comment Share on other sites More sharing options...
renom3 Posted March 1, 2017 Author Share Posted March 1, 2017 that was i am thinking too Link to comment Share on other sites More sharing options...
renom3 Posted March 2, 2017 Author Share Posted March 2, 2017 nobody have same needs ? Link to comment Share on other sites More sharing options...
MarkMc Posted March 2, 2017 Share Posted March 2, 2017 11 minutes ago, renom3 said: nobody have same needs ? What are you using that for? I ask because it looks as if you would be better off using a molding line instead of a 3D polyline or a molding polyline. IF your moldings are all relative to a single horizontal plane DON'T use a 3D line. Does this do what you need? A standard molding line will show the width of your total profile in plan. To adjust the heights of stacked molding take a back clipped section through the molding. The moldings don't update live while the DBX is open but a lot easier than hit or miss. 1 Link to comment Share on other sites More sharing options...
renom3 Posted March 2, 2017 Author Share Posted March 2, 2017 Ok MarkMc i thing you just align me in good direction before i dont make difference between polyline molding and 3d polyline molding recap if i want to draw a stack molding i first draw a polyline , convert it to polyline molding , and after chose my molding . is that right ? but i still can't do cotation quote in elevation view , but its work in cross section viiw Link to comment Share on other sites More sharing options...
MarkMc Posted March 2, 2017 Share Posted March 2, 2017 Don't need to draw a polyline first. I use "build, trim, molding line" from the menu-actually I have it set with a shortcut key. Draw line (a little longer than needed to begin with so it's easier to grab) set height (which will be listed from the subfloor so add for that) then add molding (s) bring the line back to the corner you want it to meet. To add to it just grab the DIAMOND node at the end to start a new segment. I use back clipped sections because it is easier to see the in out of the moldings in the stack, also use that to make a cad detail to dimension when done and send to layout. Link to comment Share on other sites More sharing options...
renom3 Posted March 2, 2017 Author Share Posted March 2, 2017 got it THANKS Link to comment Share on other sites More sharing options...
