Automatically generated wall won't go away
ericepv, in General Q & A
Member Statistics
Similar Content
By mborean
A lot of my work involves trussed roofs. After building the trusses, I frame the roof for the facia and varge rafters. Problem with this is that CA adds ridge boards that don't exist in trussed roofs. There doesn't seem to be a way to frame without ridge boards or to set the ridge board dimensions at 0. If there is a work around, I'd love to hear it.
Also.... Is there a way to frame a roof where one roof California or over frames over another roof. In my previous CAD, I could trim the bottom of one roof to the top of another and the framing acted accordingly. This program even added a valley plate on top of the lower roof and below the rafters of the upper roof. That may be too much to ask for, but one can only hope.
Love to hear what y'all have to say.
Thanks in advance.
By HannaForestAsh
When I place a window/door/etc. on a wall and type in the dimensions, sometimes it will move the edge of the wall instead of moving the window along the wall. (ie: if I have a 20' wall with a window on it, I want the length between the corner and the window to be 4'... instead of moving the window over on the wall, it will just extend the edge of the wall out past its original point so it's now 24'). Please help!! I'm not sure how to look up this issue so if there's a video on it already please direct me there!
By mazakintegrex
hello,
I had no idea there was a forum. this is great! I have one question for any knowledgeable experts out there!
is there a way to use auto roof planes & lock all the top heights of the roof ridges so that they all match? I've been working on my house plan for a few months now & have created manual roof planes to do what I am kind of after, but it is a real pia when a wall needs bumped out or something is revised. all the rooms are set to the same height, yet it generates roof planes all over the place [height wise].. I've had better results with baseline polyline manipulation, but still left with the same issue. I want to check a box that says "lock all full gable ridge heights" & let the pitch be the variable. basically I want full gable ridges 1,2&3 to all be the same height and span the main 3 structures of the house. but when I generate auto roofs, its a mess!
I also need gable 3 to slope over the porch at a lower pitch and join with gable 1- auto roof bones a hip over porch, if I change the roof group of the octagon nook it gets even wilder!
rocking with CA premier x12
thanks in advance!
By RenoByDesign
When I'm building my roof, I put in a dimension for my roof overhang and it doesn't matter what number I put in the dialog box, it only draws it at 20" deep. What am I doing wrong? I need to fix this so I can draw my roof lines correctly and send out for a roofing quote. I am using Chief Architect Premier X12.
Thank you, Melissa
By Designer100
I would appreciate any help working out this rear existing roof where we area adding a new cath gable closed in veranda gable. the btm of interior gable ceiling it 11'8" . Exist. evar hight up is 11'8" ht. we are tearing off old covered sloped 6x6 with plastic over it and adding this new gable roof. I cannot seem to get it worked out. See attached exist. pics.
Newell
Premier 12 x
newell.cheatheam@gmail.com
Foxland chase st.Sugarlan Porch roof 10.06.2020.plan
Foxland chase st.Sugarlan Porch roof 10.06.2020.zip
