Treated sill plates with own material?
parkwest
I don't think you can do it directly as I believe the default plate material uses the default Framing material.
So.....what you could probably do is assign different materials to studs, roof framing members, floor and ceiling framing, etc, and leave only the plates to use the default Framing material.
In this pic I have left only the plates to use the default Framing material (Color - Gold)
That's a really good solution Glenn.  Thank you!
