Member Statistics
Similar Content
By Designers_Edge
I have searched the Chief Architect website and also here. I have X14 now and want to show sliding doors on some base cabinets. Perhaps I am missing the options to adjust this in the cabinet specifications.
Would appreciate someone helping me find this. Seems like it would be available in the library with the resurgence of Mid-Century Modern. Thank you.
By Jeffcrigler
I am trying to align the orientation of the materials on a base cabinet with both drawers and doors. When I use the material painter to apply "Teak" for example, to a standard vanity cabinet, the drawers and the doors are always 90 degrees off. If I rotate thee texture of the cabinet 90 degrees, they both rotate. I need to rotate the doors or the cabinets separately. I want both the drawers and doors to have the texture apply in the same vertical or horizontal orientation.
By ACADuser
Creating a Header schedule I select one row & click the "Find Object in Plan" which takes me to the wall frame view instead of the plan view.
Do I have a setting off or is this normal?
By wazzubrad
I am trying to learn how I can get Material Lists or Schedules with Material List info, to export to Layout. I am trying to add some value to my drawings to make it easier for my guys to do takeoff's. For example; create a schedule that shows, Material Type, Qty, Description, etc. and then export that to Layout. I have found that although we can generate a Material List with this information, the Material List (AFAIK) can't be exported to Layout. If that is indeed true, then how can we get this information to show up on a Schedule? Specifically, I am trying to get my roof shingles to show up on a Custom Schedule. Any ideas on how I can tackle this?
By Bee-am
Hi everyone,
I'm experiencing an interesting phenomenon with Cabinet Shelf Specifications that contain 3 or more library-based shelves in Chief Architect Premier X13. As indicated below, when I add a 3rd unique library object (i.e. wire shelf) to a shelf, somehow the previous library-based shelf (2) "breaks" and changes from (1) to be the 3rd library object. As such, I wanted to find out if that's the intended behavior or it's a bug - and whether there are any useful workarounds. I could have used separators directly at module-level but the cabinet module needs to be covered by double doors.
