HumbleChief Posted January 22, 2017 Share Posted January 22, 2017 Got a railing detail question. Thanks oops - vid coming Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 22, 2017 Share Posted January 22, 2017 if you use a product like Dex-o-Tex, for the decking, they can flash and seal the post, all around, maybe use a steel post so no shrinkage, then cap the short wall over but the seal is underneath the cap. you can also put the post on top of the seal but screws into the top of that short wall probably need to be engineered with posts at 48 ' o.c. Link to comment Share on other sites More sharing options...
HumbleChief Posted January 22, 2017 Author Share Posted January 22, 2017 2 hours ago, DRAWZILLA said: if you use a product like Dex-o-Tex, for the decking, they can flash and seal the post, all around, maybe use a steel post so no shrinkage, then cap the short wall over but the seal is underneath the cap. you can also put the post on top of the seal but screws into the top of that short wall probably need to be engineered with posts at 48 ' o.c. Thanks a lot Perry!! I think I'm seeing a way to address the issue. Link to comment Share on other sites More sharing options...
