CADD16 Posted January 18, 2017 Share Posted January 18, 2017 Does anyone know of way to export or import ray trace configurations from one plan to another? Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 19, 2017 Share Posted January 19, 2017 Yes use a template plan for all your basic settings. You'll never have to set them again. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 19, 2017 Share Posted January 19, 2017 No. I think the closest you can probably get to an export/import process would be: Do a Save As of Plan A (the one that has the desired Ray Trace settings) and delete everything in it. Import Layer Sets, Annotation Sets, and Default Settings from Plan B Open Plan B and use Edit Area (all floors) to draw a polyline around the entire plan. Cut and paste/hold position that Edit Area Polyline from Plan A into Plan B. You can of course also just take screenshots of your settings from Plan A nd re-enter them into Plan B but it would be nice if there was an actual export/import process. Link to comment Share on other sites More sharing options...
CADD16 Posted January 19, 2017 Author Share Posted January 19, 2017 Thanks for the responses. I do have template plans with all my settings in them, just didn't have the ray trace settings in it. The second solutions is what I usually do with all my older plans to bring them up to current standards. Chief really needs a way to import / export these ray trace configurations. What is funny is you can edit these configuration defaults under the default dialog box. But when you choose to import defaults to a new plan the camera defaults don't show up. Link to comment Share on other sites More sharing options...
