dkmtek Posted January 16, 2017 Share Posted January 16, 2017 Does anyone know how (or if) you can set and hold Top of foundation walls to an absolute setting for a room, area or the whole drawing? The garage ToF moves around when trying to set stem wall heights, and change ceiling heights in one room vs another? I have attached a photo. Also, trying to connect walls, the program changes other walls when they snap together? How can I get it to stop? Link to comment Share on other sites More sharing options...
jbaehmer Posted January 16, 2017 Share Posted January 16, 2017 post a plan file so we can look at it closer Link to comment Share on other sites More sharing options...
dkmtek Posted January 16, 2017 Author Share Posted January 16, 2017 Thanks for getting back/responding to me. the file is too large. Here is the (zip file) foundation plan (ver X8). 22443 basement.plan.zip Link to comment Share on other sites More sharing options...
justmejerry Posted January 17, 2017 Share Posted January 17, 2017 Dkmtek, I assume the space on right of plan is garage space? If garage will be on main floor(level 1) then you would designate it on that level. For setting heights of TOF use the default foundation DBX. If you have garage as part of basement then just adjusting the floor levels etc... will work. Link to comment Share on other sites More sharing options...
