paskell Posted January 11, 2017 Share Posted January 11, 2017 Our county requires to frame and to brick square footage calculations. How do I get the brick, I only see that it does to outside of frame. Thank you Link to comment Share on other sites More sharing options...
joey_martin Posted January 11, 2017 Share Posted January 11, 2017 Click just outside the exterior and create a polyline. Pull the polyline to the edge it needs to be. Link to comment Share on other sites More sharing options...
RL-inc Posted January 11, 2017 Share Posted January 11, 2017 Just as Joey said- create exterior room polyline and edit to desired layer. I actually save each polyline on its own layer and then edit with any given revision to keep updated calculations readily available. 1 Link to comment Share on other sites More sharing options...
TLHomeDesigns Posted January 15, 2017 Share Posted January 15, 2017 If you're wanting heating and cooled sq footage to stud wall and brick/siding. . Go to your default settings. Click plan. . There should be an option to show Living Area to "main layer"(stud wall) or "surface layer" (brick/siding). . If you want total under roof do like the other guys said above. . Link to comment Share on other sites More sharing options...
