How to put rails on flat roof
kdaleyates
I'm probably wrong (since I'm not a CA guru) but I'd probably model it like a 2nd floor deck/balcony/or porch.  You'd have to modify it in either case I'm pretty sure to get the roofing and what ever finish for the roof (you can do that in the structure tab for the floor) and of course then you just add the rail/balustrade as you see fit. Give it a try (maybe save a copy of your plan to experiment/work on with this idea).  I sure hope I'm not way off, regardless this will give you some practice until the REAL CA experts provide the correct (best) answer.
