Clemsongrad Posted December 17, 2016 Share Posted December 17, 2016 I'm a bit confused about the dimensioning tool in two situations. In a laundry alcove when I use the interior dimension tool I assume it should measure face of drywall to face of drywall. What I get is 7' - 10", but the arrows go right to the stud. In the alcove I have a washer and dryer and a utility closet. The dimension arrows show a correct 2'-3" wide for both the washer and dryer, but the arrow stops short of the symbols and also go to the stud. so when I add up each of the three dimensions I get 7'-8". See attached capture. Link to comment Share on other sites More sharing options...
AlwaysEastern Posted December 17, 2016 Share Posted December 17, 2016 Based on your image - it looks like your three dimension string has gaps between the washer and dryer and the right wall. Check your dimension defaults. You may have it set to pick up the sides of the fixtures, furnture, etc. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted December 17, 2016 Share Posted December 17, 2016 The 3'-2" dimension appears to be a "point marker" dimension. try again with end to end dimension. Link to comment Share on other sites More sharing options...
michaelgia Posted December 17, 2016 Share Posted December 17, 2016 Looks like he accidentally used the point-to-point dimension tool because I see point markers all along that dimension string. Link to comment Share on other sites More sharing options...
Clemsongrad Posted December 17, 2016 Author Share Posted December 17, 2016 That did it! I had forgotten what point to point meant. THX guys Link to comment Share on other sites More sharing options...
