capitaldesigns Posted December 1, 2016 Share Posted December 1, 2016 I made a pony wall using polyline solids. This wall has 3 free formed glass panels on top. I wanted to rotate the unit but was unable since the rotate handle would not appear. I also tried to block them together. Again I was unable because the tool would not appear for me to do so. When I moved the wall the parts of the wall would get misaligned. Does anyone know why this might be happening ? I have attached the plan. If someone could look at my plan and let me know what I am doing wrong I would greatly appreciated any help. Thanks, Mike Arched Entry Porch.plan Link to comment Share on other sites More sharing options...
glennw Posted December 1, 2016 Share Posted December 1, 2016 Mike, My guess is that when you are trying to block the poly solids, you are including the lights as well. You can't block the poly solids and the lights together. I would block the poly solids and then block the lights separately. You can then combine those 2 blocks into a single block. Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 1, 2016 Author Share Posted December 1, 2016 Thanks Glenn. I will try that in the morning. It's 10:30 p.m. California time and its time to hit the hay. Thanks, Mike Link to comment Share on other sites More sharing options...
