Section lines display not the same in view as layout?
dskogg
I am new to x8, when i take a section and send to layout i get section lines beyond the wall that are not visible because wall is there.
Whats going on?
I have plot lines selected.
I need to send to printer tonight for meeting in the morning, hopefully someone can fill me in.
David
I see what is happening, i change the clip line to show what it sees, but in x7 it showed everything that was visible to view, not anymore?
In otherwords i have a wall that is set back on the main floor with cabinets on the back wall and a wall on the second floor that is much closer, in order to see
the cabinets on the lower floor i must move clip line beyond this point in the lower floor but then it shows what is behind wall in upper wall, makes no sense.
yes i understand this but i would have to break it not in plan but in elevation to show the lower room in elevation.
A section should cut what is in section and show what is in elevation beyond, this has changed from x7?
