Vikki_WA Posted November 27, 2016 Share Posted November 27, 2016 Is there any way to flip a light fixture vertically? I want to turn a bathroom sconce upside down so shades point down instead of up. I have tried the transform/replicate-flip vertically, but that doesn't work. Link to comment Share on other sites More sharing options...
Chopsaw Posted November 27, 2016 Share Posted November 27, 2016 Yes, no problem, a light fixture is a Symbol so you can open the Symbol Specification DBX ( Dialogue Box ) and under the 3D tab rotate 180 Degrees about the Y axis. Link to comment Share on other sites More sharing options...
Vikki_WA Posted November 27, 2016 Author Share Posted November 27, 2016 Chopsaw, Thanks for the quick reply. Unfortunately, HD Pro doesn't have the 3d tab in the dialog box. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 27, 2016 Share Posted November 27, 2016 You may have to ask someone with CA to export the rotated symbol for you. Transform / replicate not likely to work. Link to comment Share on other sites More sharing options...
Chief16Designer Posted November 27, 2016 Share Posted November 27, 2016 https://www.homedesignersoftware.com you may get better answers Link to comment Share on other sites More sharing options...
Chopsaw Posted November 27, 2016 Share Posted November 27, 2016 Sorry I did not not notice that you were HD Pro but if it is a standard library item I can rotate it for you or post your symbol. No problem with X8. Link to comment Share on other sites More sharing options...
