Korel_Design Posted November 18, 2016 Share Posted November 18, 2016 In that other CAD program, I was able to write macros that allowed me to change the properties of entities to a chosen entity. Simply type a letter such as "D", select "Entity To Change To" then select the maybe multiple entities to change. Such as a fast method to change an existing wall in an As Built to a Demo Wall very quickly without having to open the "Wall Specification" choose "Wall Types" selected a different Wall Type in the Drop Down Box then click "OK". Maybe it's here and I haven't found it yet. Link to comment Share on other sites More sharing options...
BrownTiger Posted November 18, 2016 Share Posted November 18, 2016 Current Ruby integration does not allow to change property of anything. You would be lucky if you can READ the property value that you want. Very few properties are exposed. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 18, 2016 Share Posted November 18, 2016 Here's another way to change wall types: 1. Select a existing wall type that you want to use. 2. Add it to the user library 3. Select that wall type from the user library and draw over the existing walls that you wan to change. Link to comment Share on other sites More sharing options...
