DBearss Posted November 4, 2016 Share Posted November 4, 2016 Building a simple shed roof truss and the lower overhang builds correctly but the upper overhang builds the roof projecting past the attic wall. Cannot figure out what setting to correct. Surely I am missing something obvious. The end truss builds incorrectly at the lower end. Link to comment Share on other sites More sharing options...
CJSpud Posted November 4, 2016 Share Posted November 4, 2016 Did you designate that wall as a "high shed/gable" wall? Don't know if that will make a difference but might be worth a try without seeing your plan. Link to comment Share on other sites More sharing options...
ShaneK Posted November 5, 2016 Share Posted November 5, 2016 Try this, place 1 truss, open truss dbx/select "Lock truss envelope"/open up truss detail and modify truss to your liking and truss should maintain your shape. If that doesn't work, pull house roof plane out of way and draw truss and then lock envelope and it will stay. POST PLAN Link to comment Share on other sites More sharing options...
