empty layers showing as used
houseofcards
hi all,
did a big import from a cad file, tons of stray layers, want to clean the file up a bit
the problem are layers that show as used (with red plus sign) (and so can't be deleted) but that seem to be empty
eg, when I isolate one of these layers, and, for example, select all, or zoom in and out, I can't find anything ON that layer
thoughts?
thanks
  • 2 weeks later...
hey thanks for your help --
in some cases it's just a matter of looking for some stray line somewhere and deleting it
but in others its a little weirder: if I select an object, it will show which layer that object is on in the active layer window. but sometimes one of these zombie layers will show up too -- as if there's some reference to it -- but I can't figure out how to un-reference the zombie layer
