Can I Do This Kind Of Roof In Ca?
Gloghome
isn't this what they call a Gullwing roof? Somewhat modified ,but one of the basic auto roofs at least in HD Pro... there is a tutorial in the knowledge base I think... but can be done manually with the help of the upper roof pitch checkbox and inputting the desired distance and pitch too.
Gable each end wall
single pitch side...set wall to desired pitch (no other checkboxes)
double pitch side ....set pitch on wall and check upper pitch box , put in distance second pitch starts from wall (baseline) and pitch of second roof.
and hopefully it will auto build correctly
http://www.homedesignersoftware.com/support/article/KB-00359/52/Home-Designer/Roofs/Automatically-Building-the-Basic-Roof-Styles.html#Gull
if you have SSA there is also video 1505
http://video.chiefarchitect.com/player/player.php?id=726&th=1&autoplay=
