Cristian-CDD Posted October 18, 2016 Share Posted October 18, 2016 Hi All Does anyone know what could be causing this effect? It seems to only affect one plan. when I open the blocks the dialog displays correctly. The blocks also show up in 3d views. Any suggestions? Also I can't seem to attach a picture of the problem. I haven't been on this forum for a long time and everything looks different. The blocks all show as a rectangle with a diamond pattern inside. Cristian Link to comment Share on other sites More sharing options...
Chopsaw Posted October 19, 2016 Share Posted October 19, 2016 Try again to post some screen shots or the plan file so someone can help. .jpg or .png files work well for the forum. Link to comment Share on other sites More sharing options...
Cristian-CDD Posted October 21, 2016 Author Share Posted October 21, 2016 Thanks. I did try that but it rejected the images. I'll try reducing the file size Link to comment Share on other sites More sharing options...
Cristian-CDD Posted October 21, 2016 Author Share Posted October 21, 2016 Here is the image. The "advanced uploader" works Link to comment Share on other sites More sharing options...
Chopsaw Posted October 21, 2016 Share Posted October 21, 2016 And you say that shows up the same way in 3D? All of those items look like they could potentially be symbols and somehow they have all defaulted to the same 2D Block which makes no sense at all and if you are getting 2D Blocks displayed in 3D then that is a real mystery. You may be able to fix this by opening each symbol and reassigning the proper 2D block but that does not explain how this happened. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 21, 2016 Share Posted October 21, 2016 What you are seeing is what I would call orphaned symbols. I'm not sure how, but their respective cad blocks have been deleted somehow. That box with a diamond in it is what you get when an object has no cad block assigned to it. I would send that into tech-support. If you post the plan maybe one of us can take a look too. Link to comment Share on other sites More sharing options...
