olyconstruction Posted October 18, 2016 Share Posted October 18, 2016 Hi Chiefs, This may be sort of a softball so I hope someone can help. I have an exterior wall on the second floor that cuts down into the vaulted ceiling in the main room of my house (open the camera view "El Problamo" in the plan file to get a good look). I know there has to be a way for this wall to either be cut off by the roof or something like that so it wont show up past the ceiling planes. Please let me know if you have a solution! Thank you for the help! AB JAMES - AS BUILT - 10-17-16.planFetching info... Link to comment Share on other sites More sharing options...
glennw Posted October 18, 2016 Share Posted October 18, 2016 What wall are you referring to? Have you tried Roof Cuts Wall at Bottom? Link to comment Share on other sites More sharing options...
Solution Alaskan_Son Posted October 18, 2016 Solution Share Posted October 18, 2016 I think what you're probably looking for is found under the roof tab for the offending wall...Lower Wall Type if Split by Butting Roof. 1 Link to comment Share on other sites More sharing options...
olyconstruction Posted October 18, 2016 Author Share Posted October 18, 2016 Thanks Michael, That was the answer I needed! Link to comment Share on other sites More sharing options...
