Sign in to follow this
RLConcetti
Seeking professional to put CAD drawings into Chief Architecture X8
Hello,
Our Interior Design Firm is seeking a professional to put AutoCad drawings (from our architect) into Chief Architect.  We are currently using X8.  We are looking for quality work and someone who is good at staircases, and multiple floors with a 3 story foyer.  Please respond if you are interested in this project w/ timeline and estimated cost :)
Sincerely,
Rachel
Hello.  Feel free to send me an example of the plan and we can talk.  Thanks.
I agree.  we need a little more to go off of.  feel free to contact me.
    27879
    baseja63
    baseja63
  • Similar Content
    • By Designers_Ink
      Designer's Ink is a full-service building design firm based out of Stillwater, Oklahoma; however, we have worked on projects in 27 different states and 5 different countries.  We have been in business since 1993 and have 5 designers and draftsmen on staff to serve you.  We specialize in creating stunning 3D models of your building project so you can see exactly what the building will look like before you build.  This significantly reduces the costs of change orders during construction.  Many of our clients have told us they saved more in construction costs using our services than they paid for our services due to reduced change orders and value engineering during the design.
      Once your 3D model is completed, we then produce easy to read construction documents.   We take a lot of pride in our construction documents which we customize for each client's specific needs.  Our goal is to produce our construction documents in such a way that the folks on the ground building the project have everything they need, and in a format they can use efficiently.
      With over half of our clients being from out of state, we have been working remotely with clients for years.  With the current restrictions caused by the COVID-19 pandemic, already having a system in place to communicate with our clients remotely is essential.  We have been using our system for years, so we know it works well.  We also offer one-on-one tutoring services for both Chief Architect and Home Designer Pro.  We have been using Chief Architect for 16 years.
      Please take a moment to look at our website at www.designersink.us for more information about our company.  If you would like to set up a free, no-obligation initial consultation, contact us to schedule a time that works for you.  We look forward to EXCEEDING your expectations.
      Jeff Dillon - Owner / Designer
    • By Alyssa5
      Hi,
      I have attached a couple of screenshots to best describe my problem
      Whenever I move the camera view, I get this sort of distort colouring on my walls?
      Any ideas what's causing this?
      Thanks
    • By Alyssa5
      Hi,
      I am using Chief Architect X8 on a Mac.
      I am having trouble with roof planes - I want to be able to change the baseline height but it keeps defaulting back and won't alter.
      Yet when I open the same file on another computer I can change it
      Any suggestions?
      Thanks
    • By tlconstruct
      Hi guys, I'm new here and pretty new to Chief Architect. I have Home Designer Suite 2020, not the Premier version. I'm a graphic designer, just working up plans for a builder to show his concepts to clients. I'm having problems with a shed roof. I've looked up a bunch of videos and steps on how to do it, but it's not coming out quite right. I'll attach images.
      I have the 2nd floor height set to 2 feet, because that seemed to be the only way to get the roof to go Shed. The front (high) wall of the 2nd floor needs to be about 10 ft tall, and the back wall needs to be 2-3 ft tall. I have the front wall marked as High Shed/Gable Wall, the back as a Knee Wall, and the two side walls as Full Gable. In the video I watched, the side walls automatically adjusted to fill in, and the high shed wall bumped up as well to the height it needed to be for the roof pitch (which I have set as 3" in 12). I just can't seem to figure out where I've gone wrong and would very much appreciate some advice!
    • By jheath21
      I'm working on this project for a summer class.. I'm finished and was taking perspectives and a couple ray trace. I changed some of the settings in the ray chase for lights and such, and then I move to another part of the building and the ceiling is gone!! What did I do wrong? And how do I fix it?! Please help!!
      I attached a snap of the outside of the building...no ceiling in the center (also I know my glass panels extend above the ceiling don't judge me)
