Sign in to follow this
BethVanDeusen
Explode CAD Detail Block Text Disappears
I am using a CAD detail from the bonus catalog for a wall section. When I explode the block to edit the section, the text labels disappear. I've tried seeing if something is turned off in the layer display options to no avail. Attached is an example of the original detail and the detail when I explode it. I can explode/edit CAD details from the regular library. Any suggestions?
I would recommend switching to the "All On Set" and open its "Display Options" to make sure ALL layers are checked "on", once the text reappears you can then find out what layer that text is on. There can be no other answer.
When you explode a block, if the block is greyed out, immediately open it and place it on the layer you want it to be.
    27491
    alexvictory
    alexvictory
