Aunttieem Posted August 4, 2016 Share Posted August 4, 2016 I have created this beautiful octagon ceiling following the video instructions by David Michael's video. Everything works great with one exception. The sides of the walls of the 8" raised portion show a gap in the camera view. It seems to look fine in the floor plan view, Here is the dropbox link. The room in question is the office to the right of the entry door as you look into house. https://www.dropbox.com/s/p9pvp4yuy32wurn/Kim%27s%20FINAL%20FP%20-%20ALTERNATIVE%20-%20Origianl_expanded%20ext%20wall%20width.plan?dl=0 Thank you for any suggestions! office ceiling.pdf Link to comment Share on other sites More sharing options...
Aunttieem Posted August 4, 2016 Author Share Posted August 4, 2016 Just added link to plan on google drive. https://drive.google.com/file/d/0Bw_HN1RjkWDscm56Q3dxcm1TS0U/view?usp=sharing Link to comment Share on other sites More sharing options...
rlackore Posted August 5, 2016 Share Posted August 5, 2016 Can't access the Google docs link. Maybe you could attach the plan to your forum post. Link to comment Share on other sites More sharing options...
Aunttieem Posted August 10, 2016 Author Share Posted August 10, 2016 Here is the plan in dropbox. https://www.dropbox.com/s/p9pvp4yuy32wurn/Kim%27s%20FINAL%20FP%20-%20ALTERNATIVE%20-%20Origianl_expanded%20ext%20wall%20width.plan?dl=0 Thanks for any suggestions. Link to comment Share on other sites More sharing options...
ShaneK Posted August 10, 2016 Share Posted August 10, 2016 Won't open for me Link to comment Share on other sites More sharing options...
Aunttieem Posted August 10, 2016 Author Share Posted August 10, 2016 Hopefully this zip file works. I tried the edit- edit area, but it changed several things so you would not see what my issue is in the office. Thanks again Backed up plan - Shortcut.zip Link to comment Share on other sites More sharing options...
Aunttieem Posted August 10, 2016 Author Share Posted August 10, 2016 Sorry... long day. Kim's FINAL FP - Origianl_expanded ext wall width.zip Link to comment Share on other sites More sharing options...
Aunttieem Posted August 11, 2016 Author Share Posted August 11, 2016 This is what shows in my camera view. It looks okay in floor plan view, but I see gaps at the vertices in camera view. ceiling.pdf Link to comment Share on other sites More sharing options...
rlackore Posted August 11, 2016 Share Posted August 11, 2016 Everything looks fine on my end: 1 Link to comment Share on other sites More sharing options...
Solution ShaneK Posted August 11, 2016 Solution Share Posted August 11, 2016 I get same view as both Solver and Rlackore, I think in original pdf you posted your molding polyline layer was turned off. One of the ceiling planes had a peak height 1/16 higher but that should not cause any serious issues. Check your layers. Link to comment Share on other sites More sharing options...
