Backsplash above stove?
beckyz
"quote"
With no base cabinet I think the Soffit Tool is the easy Solution unless you have X6 of course with custom backsplashes.
someone may followup on this:   If you have a wall cabinet above your hood ,but still have the slide in Range ,does trying the checkbox for "build backsplash down to Base cabinet" , in the Wall cabinets DBX, build it  down to 36" counter height or not? , not sure it works if there is no base cabinet?
Yes me :)
It is possible to use the  Wall cabinet's Backsplash checkbox to generate a backsplash down to the Countertop Or lower as seen in the images . I made the base cabinet standard width BUT made it 1/2 thick and 1/2" high ( making higher changed it's look) ...it looks like the baseboard in the image, but still allows a standalone range to be slide in.
post-315-0-53638000-1402407105_thumb.jpg post-315-0-67248900-1402407119_thumb.jpg
