ACADuser
Mirror a layout Box?
I have a 4 unit townhouse & want to mirror the middle & end unit to create a 4 unit elevation.
Any ideas?
Display the Elevation and create a CAD Detail from View.  Then in that CAD Detail you can Mirror Copy.
I figured it out. Make CAD detail from view & then mirror the details lines, send that to layout.
Although this works you loose the LIVE update or any automatic update abilities.
Oops, You were posting at the same time as me.
Thanks Joe.
Alan,
The other option is to use Edit Area to copy the entire Plan and mirror it so that you have a 4 unit.  Save that as a separate Plan File and then send the 4 unit elevations to your Layout.  You can send as many different Plans to the same Layout as you want.
Well so far all i needed is the mirrored elevations (front & back)
If the ask for mirrored floor plans, that will be the method I use.
Thanks again
    28310
    nrafiq
    nrafiq
