Add item to schedule
ShaneK
Go to solution Solved by Alaskan_Son,
  • Solution
At least 2 ways you can do this...
1.  Block the item, open it, and on the General tab check "Treat As One Object" and under "Include In Schedule" check "Cabinet".  Make sure your cabinet schedule is set to include Other under the heading "Objects To Include".
2.  Place the object into a blank plan, Export 3D model.  Then Import 3D Symbol and select Cabinet from the list of categories.
