Brick librarys
Bill_Shaw
https://www.brick.com/architect/tools.htm  Download the Masonry Designer from Acme Brick.  You can create exactly what you want, save it as a seamless texture, and import it into Chief.
Bill, I would recommend the Masonry Designer from Acme Brick too. If you use that, I would also create a soldier brick image too so that you'll have both of the same brick.
  • 1 year later...
