Diamond-built Posted April 26, 2016 Share Posted April 26, 2016 First time printing a drawing and I print out a full over view and only thing that is showing up is the roof and doors and windows and garage doors. How can I get it to print everything? Link to comment Share on other sites More sharing options...
English Posted April 26, 2016 Share Posted April 26, 2016 Try sending the floor plan to a Layout and then print from there. Printing is normally not done from within a Plan. Alan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 26, 2016 Share Posted April 26, 2016 also try to center it on the page using the center on page tool. Link to comment Share on other sites More sharing options...
Diamond-built Posted April 26, 2016 Author Share Posted April 26, 2016 Thank you I will try that and take the terrain off. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 26, 2016 Share Posted April 26, 2016 also save as PDF then print that should work Link to comment Share on other sites More sharing options...
Diamond-built Posted April 26, 2016 Author Share Posted April 26, 2016 I have not created a template page yet maybe thats the problem. Because it's still not printing out correctly Link to comment Share on other sites More sharing options...
English Posted April 27, 2016 Share Posted April 27, 2016 You don't need a template page -- just click on New Layout, save it, go to your the floor in your Plan and click on Print>Drawing Sheet Setup, set the paper size and scale. Then click on Send to Layout. From the Layout page click on Print then Print to PDF with the same paper size, save the PDF. Alan Link to comment Share on other sites More sharing options...
michaelgia Posted April 29, 2016 Share Posted April 29, 2016 ...also make sure you "update view" if not checked to be done automatically before printing. Link to comment Share on other sites More sharing options...
