RobUSMC Posted April 10, 2016 Share Posted April 10, 2016 I am trying to draw a 5 unit bow window without any framing between each window (See attached pic) After I insert ans size the bow then resize the actual windows it still shows framing between each window. I have checked the box "No framing between components" but no help? Im I just missing something or is there a trick? Thanks for any help. Rob Link to comment Share on other sites More sharing options...
MarkMc Posted April 10, 2016 Share Posted April 10, 2016 check connect outer casing. If you need more adjustment after that tab to open one of the windows. Link to comment Share on other sites More sharing options...
RobUSMC Posted April 10, 2016 Author Share Posted April 10, 2016 Connect outer casing is checked. I can tab and open one of the windows but it will only resize to a max of 11" wide where I need 22" wide which they would be without the framing between them Link to comment Share on other sites More sharing options...
RobUSMC Posted April 10, 2016 Author Share Posted April 10, 2016 Eric, If you see my attached screen shot I have those selections made Link to comment Share on other sites More sharing options...
RobUSMC Posted April 10, 2016 Author Share Posted April 10, 2016 Here is the plan Day Kitchen As Built Roof.zipFetching info... Link to comment Share on other sites More sharing options...
MarkMc Posted April 10, 2016 Share Posted April 10, 2016 Not sure why it's not working for you. Attached, placed window, sized the bow side to side, checked options off, then-tabbed to open one window, changed casing size, height, and got rid of sills. You aren't using a bay instead of a bow are you? Those are more of a problem-still can get close but harder. Link to comment Share on other sites More sharing options...
RobUSMC Posted April 11, 2016 Author Share Posted April 11, 2016 No. I am using a bow not a bay Link to comment Share on other sites More sharing options...
RobUSMC Posted April 11, 2016 Author Share Posted April 11, 2016 Lets try this again. Closed plan then zipped Day Kitchen As Built Roof.zipFetching info... Link to comment Share on other sites More sharing options...
RobUSMC Posted April 11, 2016 Author Share Posted April 11, 2016 I deleted the bow window completely, started over and inserted a new bow and entered the width and depth. Looking at it in both plan and camera view the windows show to have no framing between them but as CA default they are only 36" tall. I select one of the windows and changed the width to 22" as I need and all i still ok...but as soon as I changed the height to 72" it automatically is putting framing between each window and narrowing them to 11". I dont have a clue. Bug, operator error, I shouldn't be working on a Sunday... Im at a loss Link to comment Share on other sites More sharing options...
MarkMc Posted April 11, 2016 Share Posted April 11, 2016 You can change the overall width of the bow but Don't change the width in the individual window dbx just the height, and casing width there. If you change the component windows to more than some mysterious magic number it will do what you are seeing. I've not found a way around it. I settle for a decent look and accurate overall width of the bow. Link to comment Share on other sites More sharing options...
