Dennis_Gavin Posted April 8, 2016 Share Posted April 8, 2016 I have a cad block for a duplex switch and cannot figure out how to enlarge it. Been in and out of cad block management, cad detail management and have added a version to my user library but cannot seem to find how to get it into the plan and substitute it for the existing. Can someone slap me upside the head??? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 8, 2016 Share Posted April 8, 2016 Drop that CAD block into your plan. If you have "automatically Purge CAD Blocks" checked in the CAD Block Management dbx, it won't be available for use otherwise. Once the CAD block is in your plan, open the SYMBOL dbx for the duplex switch. Click on the 2D Block tab and select your block from the list. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 8, 2016 Author Share Posted April 8, 2016 Michael, I had already done that and have the cad block enlarged BUT when I open the symbol for the switch that enlarged cad block is not available. What I am doing wrong? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 8, 2016 Share Posted April 8, 2016 Are you placing the CAD Block into the plan first? That's an important step. You won't be able to select a block from your library. You also can't simply resize and rename the existing CAD block. You need to explode and re-block it first. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 8, 2016 Author Share Posted April 8, 2016 I sure am missing something. The cad block comes up when I open cad block management for the plan but when I open the symbol and go to cad block and scroll down it is not in that list. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 8, 2016 Share Posted April 8, 2016 Hmmm. Not sure if this will help or not, but I reassigned a CAD Block somewhere in this video. Maybe check to see if you catch anything you might be missing... Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 9, 2016 Author Share Posted April 9, 2016 Michael, See attached pics. Enlarged block is listed in block management but not listed in the symbol dbx when I go wo select it. Sorry fir the long delays but things have been hectic! Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 On 4/9/2016 at 4:18 PM, Dennis_Gavin said: Michael, See attached pics. Enlarged block is listed in block management but not listed in the symbol dbx when I go wo select it. Sorry fir the long delays but things have been hectic! Can you attach a plan with the CAD block and your symbol? Link to comment Share on other sites More sharing options...
JoeOster Posted April 9, 2016 Share Posted April 9, 2016 A block can only me assigned to a symbol with "one level" of blocking. Does you Block have blocks within it? If so explode all blocks within your block, Re-block as a single block, rename and it should be available for a symbol. 1 Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 9, 2016 Author Share Posted April 9, 2016 Here you go stripped plan.zipFetching info... Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 Joe nailed it. You had a block within a block. Just explode and reblock and you're good to go. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 On 4/9/2016 at 5:30 PM, JoeOster said: A block can only me assigned to a symbol with "one level" of blocking. Does you Block have blocks within it? If so explode all blocks within your block, Re-block as a single block, rename and it should be available for a symbol. By the way, thank you Joe. This is something I wasn't fully aware of. Good piece of information to have. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 9, 2016 Author Share Posted April 9, 2016 I thought I tried that but did not get the icon to unblock???? Maybe I was doing something else. After a while you forget what you did and didn't do! Thanks guys!! Got it! Link to comment Share on other sites More sharing options...
