rfcomm2k Posted March 17, 2016 Share Posted March 17, 2016 I am trying to use CA to design from scratch a structure that does not follow any of the conventional methods in the software. To be exact, I have several sheets of 1/4" tempered glass that I intend to use to construct a greenhouse, but need a design first. In a very old version of Turbocad and in Autocad LT I could create a 2D object (for example the end view of a 2x4 with notches cut in 2 corners, giving it a T shape). I could then extrude this object to whatever length desired. In this case again, the 2x4 is intended to be a support for the glass, so there are rabbets cut in 2 opposite edges to allow the glass to sit on the 2x4 and will be held in by glacing applied just as if it were a small pane of glass in a sash. I have not been able to see how I can create these objects in CA. Can it be done? Link to comment Share on other sites More sharing options...
rlackore Posted March 17, 2016 Share Posted March 17, 2016 I think the easiest method is to draw the section as a closed polyline, then convert the polyline to a polyline solid to give it depth. You could also save the closed polyline in your user library and use it as a molding profile. You could also use solid primitives and boolean operations to create the shape, but then you can no longer dynamically change the length of the object. Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted March 17, 2016 Solution Share Posted March 17, 2016 1. 3D Faces (Primitive Solid) can be extruded. 2. Molding Polylines use a Profile and extrude that 3. Solids can be "Exploded", resulting in 3D Faces (see note #1) Link to comment Share on other sites More sharing options...
rfcomm2k Posted March 17, 2016 Author Share Posted March 17, 2016 Thank you both. I find that the 3D face method seems to be easiest for me. I suppose I will find out later whether this is the best method, but for now it is doing what I want. Link to comment Share on other sites More sharing options...
