Gull Wing Roof
dkmtek
I am having trouble trying to draw (Auto roof generate) a gull wing roof. It shows the offset (Distance from top plate to be about 10' offset even though it says "0" in the description?  Can (and is so, how) I draw a gull wing roof manually? And/or what am I doing wrong in trying to generate a gull wing roof?
You want to select the walls on the non-gable ends (if its a traditional gull wing) and set upper and lower pitches to what you need and auto-build roof will make the roof to spec.
If you are trying to build a modern gull wing roof then you really need to use roof planes manually.
