PaulinColorado Posted February 28, 2016 Share Posted February 28, 2016 Good morning, New to CA, X8 (formally using X5). (current working plan imported from X5) RE: finishing up a new modern, 2-story plan with multiple exterior finishes: When in orthographic view, I'm trying to select only one (or group selecting several) wall using "Select Objects" arrow so that i can change exterior materials. CA is selecting the floor (when I "open object") It defaults to "room specification" on a particular level instead of the walls...what am I missing as I would like an efficient method of comparing different exterior wall finishes. I was previously taught "never" to use the spray can on exterior surfaces... thanks, Link to comment Share on other sites More sharing options...
dshall Posted February 28, 2016 Share Posted February 28, 2016 .....I was previously taught "never" to use the spray can on exterior surfaces... thanks, Nuts, give it a try, you will like it. It has been improved in X8. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 28, 2016 Share Posted February 28, 2016 I belive you need to select the top of the wall section not the face. Don't need this much but if you select the face try pressing the Tab key to see if it selects the next level. I use the the material painter all the time. I believe most of the cautionary comments is that you really have to make sure you have the right painter mode selected (bottom left screen) and be very careful to make sure the target is correct (target displays in lower left bottom of screen). It's very easy to actually target something hidden from view or if the mode is not set correctly you will get unexpected results, there are times when this is not obvious in regular camera view modes and may go completely unnoticed. Graham Link to comment Share on other sites More sharing options...
PaulinColorado Posted February 28, 2016 Author Share Posted February 28, 2016 Thanks for the quick replies...selecting "attic walls" is one-mouse-click; main walls- still get room specification dialog. I can change the "wall types" in the floor plan layers, but this is not efficient...still looking for input... Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 28, 2016 Share Posted February 28, 2016 Click on the wall, press tab, then select open object. Graham Link to comment Share on other sites More sharing options...
Solution PaulinColorado Posted February 28, 2016 Author Solution Share Posted February 28, 2016 Thank you Eric...sometimes I wonder how I make it through the day, ha! obvious once you pointed it out. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 28, 2016 Share Posted February 28, 2016 Just a note. When you set to select the wall first in preferences then the tabbing room/wall function is disabled. To get the room you will need to click on the floor region. Not sure but if you are in an elevation view then there appears to be no way to get the room DBX. Link to comment Share on other sites More sharing options...
