Nicinus Posted April 26, 2014 Share Posted April 26, 2014 When I choose a new layout I get the info "This file was generated by a pre-release or beta version. If you have problems reading this plan, open and then save it in a release version." I did select save, but I still get this message every time I start layout, even if it is the first thing I do without a plan loaded. Chief then typically crashes when I start using it and freezes the machine. Last time I rebooted because of this my machine froze just by starting Chief. After this I reinstalled Chief with the repair option, and although Chief now starts properly, I still get the info about the layout file having been generated by a pre-release or beta. It seems to me as if a reinstall didn't flush out the old template files or something, and that there is a corrupt file somewhere? Since apparently a reinstall gave me new template files, where can I find those? I would have called support about this if it weren't for the weekend, and I need to get some stuff done. Anyone bumped into this problem? Nic Link to comment Share on other sites More sharing options...
MarkMc Posted April 26, 2014 Share Posted April 26, 2014 I'd go to the chief data folders and find a layout to open from explorer- if it doesn't crash then change your preferences to that file. Link to comment Share on other sites More sharing options...
