javi_iq
Reinforced Concrete Structure
Dear Friends,
I would like to design a Reinforced Concrete Structure using Chief Architect, but I can not find the options easily.
To define the Foundations (but not footings) are more intuitive, but the rest of elements (pillars, columns, slabs, beams, etc) made in concrete, is quite difficult for me.
Please, see the attached picture ("structura1"), to have an idea about what I would like to do, before to design the rest of elements (roofs, rooms, materials, etc).
Thank you in advance.
The easier bits:
Foundation walls and strip footings can be created using the Build>Wall>Straight Foundation Wall tool. Use the Room Specification>Structure tab to define wall heights, etc.
Isolated strip footings and footing pads can be created using the Build>Slab tool.
Enlarged footings beneath foundation walls can be created using the Build>Slab>Square Pad tool.
Slab-on-Grade floors can be defined using the Room Specification>Structure>Floor Structure options.
Columns can be created using the Build>Framing>Post tool.
The difficult bits:
One-way and two-way slab floors can't be automatically created. You can define the overall depth of the floor in the Room Specification>Structure tab, but accurate modeling of the slab profile will have to be done using other methods. A one-way slab could be created using a "floor slab" with rectangular slabs as the beam sections:
A two-way slab could be created in a similar manner. There are other methods, such as using soffits, etc., that may work better for you. You could even define joists as rectangular concrete sections. Learning the tools, then playing with them in unconventional ways, can help you achieve what you're after.
Concrete stairs are also a problem. Chief's stair tools are lacking in many ways. The Reference Manual explains how you can create a reasonable facsimile of a concrete stair, but you may be better served by creating a CAD profile in section view and converting it to a polyline solid.
Good luck.
javi_iq (please give us a name to address you by) - you could use rectangular polylines in elevation, break the edges to the profile of your floor sections, and convert them to a polyline solid. That could be adjusted in plan for proper width, etc. Problem with this method is you don't have as much automation and control if things should change later. You will probably still have to use a different element, slabs, other polyline solids, tools, etc. for the perpendicular floor beams. Others will no doubt chime in and give other methods to consider.
Your project is certainly an "outside of the box" for CA, but it can be done.
Mike
Dear Friends, Mike and Robert,
Definitely it is a "outside of the box" using CA. But it can be done using polylines, exported through CAD blocks.
Another option is to configure the different dimensions (Room Specification>Structure > Floor Above (A), Ceiling (B), Stem Wall Top ©, etc). Using this configuration, in combination adding Foundations and Post with Footings, could be done.
Thank you for your support.
Javier Martínez
X6-X7
Windows 10, 64 bits
Intel® Core i5-4200U 1.60 GHz
Inter® HD Graphics 4400
    27825
    ChiefDallas
    ChiefDallas
  • Similar Content
    • By SpeleoWorm
      I have created a number of different wall types to show proper dimensions (i.e. when one side of the wall is 5/8" Type X and the other side is 1/2" drywall) as well as to calculate the correct material counts and to show the proper information in the schedules.  Unfortunately doing that seems to have a down side...it changes the framing as if they were separate walls instead of the same wall with different materials on them.  I have seen the following side effects (colors refer to screenshots below):
      (Green Arrow) In unfinished rooms such as an attic storage space which only has a subfloor but no drywall, the walls get pushed up into the rafters by what appears to be 3". (Red Arrows) The floor joists and top/bottom plates are cut in the middle when they should be continuous pieces of wood.  In addition, you can see that the walls which are produced are not boxed at the end...the top & bottom plates stick out at the end. (Purple Arrow) Parts of the gable wall are not created.  In this case you could argue that it is not needed, but if a builder makes a wall he is not going to leave a hole in it. (Blue Arrows) An extra stud is added to a room that has no drywall, and therefore doesn't need nailer studs.  In addition, it looks like the other stud needed as a nailer for the finished room in the middle is missing from the plan view of the framing (see 2nd screenshot).
      Am I doing this all wrong (creating separate wall types), or is there a way to use them and fix (any of) the issues I mentioned?
      Thanks in advance for any help!
      PS - I am a little surprised that the wall finish is not part of the room settings (like the floor & ceiling already are)...that would allow you to have continuous walls and still have different materials in each room (i.e. greenboard in the bath, 5/8" type X in a garage, unfinished in an attic, etc.
      Example of Wall Issue.plan
    • By MichaelJerome
      Hi Again,
      After sending this plan to my engineer he has requested several things that are list in the pdf files.
      I can not combine framing layer 4 and 2 that are basically the same wall but separated. With the headers that the engineer is suggesting I will have to raise the ceiling, roof and trusses. I also need to have a soffit retained over the entry for lighting but have the outside ends match with no boxed soffit.  The are layers in the wall that appear as shapes in the drywall that I cannot seem to find or eliminate.  The windows cannot be lowered since the closet ceiling and the closet roof limit the movement in the wall.  I have drawn red lines for the framing that the engineer has requested but can't place the framing on the same layer. I would appreciate any insight on how to accomplish this so I can get it back to him for review and have accurate details for the layout and city plan review.
      Thank you,
      Michael
      Megale Center Plan 2.7.20.zip
      2nd Wall Layer 4 Megale Center Plan 2.7.20.pdf
      Megale Center Plan 2 2.7.20.pdf
      Wall Layer 2 Megale Center Plan 2.7.20.pdf
    • By RichM1
      Summary: We're creating a vaulted tray ceiling in a house that started as a double-wide mobile home. I want to model the existing "trusses" so that I can figure out how to do the rafters to frame out the new ceiling. I cannot figure out how to do this though.
      Details:
      This house started out as a double-wide mobile home. It's been remodeled several times, huge portions added, walls rebuilt in places, rooms moved, walls removed. But the roof structure through the middle of the house is a 2.5/12 pitch, framed as follows: 2x2 rafter, 2x2 joist, 16" OC, with 12" pieces of 1/4" paneling used as gussets every 12". The tall wall has 1/2" plywood as a ridge beam.  I attached a drawing that shows each side.
      I tried changing the rafter and joist settings to 1.5" x 1.5", but it insists on building roof framing with 6" rafters floating above the walls, and framing the tall wall with studs that are in the room wall below.
      I tried to manually draw the framing in like the CAD detail drawing I attached, but I can't figure out how to rotate the 2x2 rafter to the 2.5/12 pitch angle. I figured I'd draw one "truss" manually, and then replicate/copy it across every 16". But after about 6 hours (admittedly I'm new to this app) I still couldn't figure it out.
      I put both sides together, and added the 2x6 rafters and 2x4 cross brace. Then we plan to cut the trusses back flush with the rafters and brace. The wall will be coming out of the middle. There's no code here, unincorporated county, so no building inspection to send this through.
      Is there a way I can take this CAD drawing and use it for the actual rafters - extrude the 2D shapes into 3D?
    • By mattradk
      I am using CAX6 and am trying to get the exterior dimensions of a residential structure to reach to the extent just under the siding. From inside to outside, the exterior wall should have 1/2" wallboard, 2x6 stud walls, 1/2" OSB, 2" rigid insulation, and then siding for which I've allowed 1/2". All of the wall components will sit on the platform except for the siding, which should cover the rim joists.
      I believe I have the correct dialog box and selections to do it (or maybe not …. see attached screen shot). However, after I make the selections in the Wall Type Definitions dialog box and back out of the dialog boxes leading there, I find that the cross section is incorrect, and the outside of the siding is flush with the platform. If I return to the Wall Type Definitions dialog box to find out why, I find that my selections have not been saved.
      I'm careful to make sure that I back out of each dialog box correctly (Clicking OK, OK, Done, etc.) but the changes I make are not saved.
      There's probably something I need to select or conditions I have to meet, but darned if I can figure them out after hours of messing with it.
      Any thoughts on what I'm doing wrong?  Thanks!
    • By tremhomes
      Is it possible to create a bi level single open web floor truss?  I have a 6" step down shower in the middle of a truss span and cannot create a single truss to show the recess for the shower floor.  Don't know if the x12 can automatically create this or not or if it is possible to manually alter the floor truss.
      I did create a room for the shower with a -6 floor elevation and tried to draw a truss but is creates a 0 floor elevation thru the shower.
