mattyt12 Posted January 14, 2016 Share Posted January 14, 2016 I know that you can set the sun angle defults for Latitude, Longitudinal & Timezone but can you set a default date and time as well? Link to comment Share on other sites More sharing options...
glennw Posted January 14, 2016 Share Posted January 14, 2016 Matty, You can place a Sun Arrow in your template plan with the time and date. I have complained about this in the past as I would normally use winter solstice rather than the current date. Link to comment Share on other sites More sharing options...
mattyt12 Posted January 14, 2016 Author Share Posted January 14, 2016 Thanks Glenn good solution, I suppose I should spend some time on my master template to add hourly sun angles/layersets to suit. Link to comment Share on other sites More sharing options...
