Stair Riser/trim Material
KKB9750
Go to solution Solved by Joe_Carrick,
Hello,
Can I only select one material for both the riser and the trim material within a stair specification?  I'm trying to show a carpeted stair with a wood trim board, but it seems like I can only select one material for both the trim and the riser.  Am I missing something?
Thanks
Joe that is a good suggestion for this but we should be able to select the grains and the direction of the grains for each item, thread, riser and the stringers for each set of stairs we produce not all want carpeting or maybe just want a runner for carpet
