Cabinet Adjustment
gelbuilding
In cabinet DBX- front tab- use "framed" traditional overlay- if you doing frameless cabinet set your separation to say 20mm; then set your vertical overlap to 40mm, change your top seperation to something like 25mm (i used inches in the example-you can convert)
Glad it helped.
I often have to override the full overlay or the frameless settings since the four brands I handle (and most of the other 2 dozen I've worked with) that does those has one reveal for the tops of cabinets and another for the bottom. Creates other problems when dealing with that though- I can get the elevations and the perspectives to look correct but have to make secondary cabinets to show section through a cabinet or any that I also have to show openings for ordering. Haven't found a solution and don't expect one.
