facer_03 Posted October 18, 2015 Share Posted October 18, 2015 Tile pattern generator Modern patterns now can be easily generated with output to seamless jpg patterns. DWG files in 2d to match created patterns. http://www.mosa.nl/generator/#search home website: http://www.mosa.nl/us/ Mosa Pattern Generator Mosa Pattern Generator instruction video https://www.youtube.com/watch?v=8dcRQMJ8-Lc The Mosa Pattern Generator is a simple online design tool that can be used to design unique and creative patterns. The generator’s library contains a large selection of grids and patterns for inspiration, all developed by the Mosa design team. The patterns can be applied directly as they are and can also serve as the basis for a custom pattern. DWG 2d Grids of Patterns http://www.mosa.nl/us/services/download-center/autocad-2d-grids/# About Mosa Mosa A day in the Life - English subtitles https://www.youtube.com/watch?v=5O75TkqJgO8 As a Dutch tile manufacturer with over 130 years of experience,Mosa offers unique and distinct tile concepts for walls, floors, facades and terraces. In the USA the products of Mosa are promoted, sold and distributed exclusively by Mosa USA, Inc. 4 Link to comment Share on other sites More sharing options...
jcaffee Posted October 18, 2015 Share Posted October 18, 2015 Very easy to use. Thanks for posting! jon Link to comment Share on other sites More sharing options...
mm407p Posted October 19, 2015 Share Posted October 19, 2015 Good information We should convince Chief Architect to produce a "tile generator" along the same idea - it would be a great improvement to the program. As far as I can work out - at the moment you can adjust the tile position in ray trace but not when you are using room fills which is a pity The tiler needs to know where you want the tiles to start from, and where to end with half tiles etc - much needed work here by Chief Architect. Lets hope the next version has a few more improvements! 2 Link to comment Share on other sites More sharing options...
johnny Posted October 19, 2015 Share Posted October 19, 2015 Thank you for posting!!! Link to comment Share on other sites More sharing options...
GriffDesign Posted October 20, 2015 Share Posted October 20, 2015 Definitely agree with MM407p. One of the biggest things lacking in chief is a tile tool. The ability to load Multiple faces, ie 9 faces, into the material object when you create it makes such a huge difference in the realism of the rendering. You simply can't show a client a single face of a V3 or higher face variant tile and get a real representation. Being able to then access materials to input in a pattern generator would be huge, especially if it had a manufacturers grout catalog that was adjustable for size and color. As it is now you have to generate the JPG play with sizes and you can get it pretty close, but it can be a time consuming endeavor and the results aren't always what they could be. Side Note: When using chief to determine things like Rough Framing height for a shower bench, niche, pony wall, etc. it can be a pain to calculate actual tile H, grout joint H, Shower pan thickness, shower floor tile thickness, finished tile thickness, thinset, and finished tile backer. When you do you can produce a wall tile layout without cuts due to vertical layout that is really awesome. Does anyone know an easier way to determine this? 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 22, 2015 Share Posted October 22, 2015 That's pretty stinkin' cool. Thanks for sharing facer Link to comment Share on other sites More sharing options...
Wilcarpet Posted December 11, 2015 Share Posted December 11, 2015 Working for a bathroom remodelor, this just changed my life! If anyone has any similar links to post that would be awesome! Link to comment Share on other sites More sharing options...
