SNestor Posted October 13, 2015 Share Posted October 13, 2015 I'm wondering if I have changed some default behavior somewhere. When using the leader line tool...it seems to me the standard behavior should be - you click where you want the arrow to be...drag the line for the 1st segment to where you want to change direction...then let go and drag the horizontal segment to where you want to place text. For some reason...probably user error...I can draw the 1st segment...but when I let go of the mouse to draw the 2nd segment the text box opens. This behavior occurs no matter what template I use to create a plan...even the OOB plan template. Any ideas as to what I've done to create this problem... Thanks... Link to comment Share on other sites More sharing options...
Dermot Posted October 13, 2015 Share Posted October 13, 2015 Check your text preferences. You may have set your number of segments to 1 instead of 2 which is the normal default. Link to comment Share on other sites More sharing options...
SNestor Posted October 13, 2015 Author Share Posted October 13, 2015 Check your text preferences. You may have set your number of segments to 1 instead of 2 which is the normal default. That was it...thanks much! Link to comment Share on other sites More sharing options...
