zowie123 Posted October 7, 2015 Share Posted October 7, 2015 Hi, Using the Adjust Material tool which opens the Define Material dbx...From there what's the fastest way to copy the same material and change its texture--I want to adjust the same material differently in the same room. the way I've been doing it takes too long. Thank you, Barry Link to comment Share on other sites More sharing options...
kMoquin Posted October 7, 2015 Share Posted October 7, 2015 Don't use Adjust Materials. Click the spray can (Materials Painter) Select the material you want from the list and hit the copy button. Link to comment Share on other sites More sharing options...
zowie123 Posted October 7, 2015 Author Share Posted October 7, 2015 Don't use Adjust Materials. Click the spray can (Materials Painter) Select the material you want from the list and hit the copy button. So...Identify material name using the Adjust material, click on material painter (spray can), click plan material, find name in plan material list (unfortunately plan material dbx doesn't have a search box or we could past the name instead of searching down a list of 500). copy and adjust this material then spray? That's the fastest method that I know. Anyone other ideas? Thank you, Kevin, Barry Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 7, 2015 Share Posted October 7, 2015 So...Identify material name using the Adjust material, click on material painter (spray can), click plan material, find name in plan material list (unfortunately plan material dbx doesn't have a search box or we could past the name instead of searching down a list of 500). copy and adjust this material then spray? That's the fastest method that I know. Anyone other ideas? Thank you, Kevin, Barry First click on the material eyedropper and select the material. Then click on the material painter (spray can). The material you previously selected will automatically be highlighted. Then either copy and adjust or add to library and adjust. Easy peasy. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 7, 2015 Share Posted October 7, 2015 First click on the material eyedropper and select the material. Then click on the material painter (spray can). The material you previously selected will automatically be highlighted. Then either copy and adjust or add to library and adjust. Easy peasy. For the record, I didn't previously realize how easy this actually was until Kevin suggested using the spray can and going through the list. I checked to see how fast that method was and discovered the eyedropper thing by mistake. Previously what I had always done was to use the library browser to search for the material I wanted>Show In Browser>Copy>Paste into my user catalog and then adjust from there. The new way is definitely faster and easier. Link to comment Share on other sites More sharing options...
WendyatArtform Posted October 8, 2015 Share Posted October 8, 2015 So...Identify material name using the Adjust material, click on material painter (spray can), click plan material, find name in plan material list (unfortunately plan material dbx doesn't have a search box or we could past the name instead of searching down a list of 500). copy and adjust this material then spray? That's the fastest method that I know. Anyone other ideas? Thank you, Kevin, Barry That really is THE way. I do a lot with materials. You might find other ways to get the look you want for a brief shining moment. But this is the way to do it correctly and have control. Link to comment Share on other sites More sharing options...
zowie123 Posted October 15, 2015 Author Share Posted October 15, 2015 First click on the material eyedropper and select the material. Then click on the material painter (spray can). The material you previously selected will automatically be highlighted. Then either copy and adjust or add to library and adjust. Easy peasy. Dude! That's awesome. At first i didn't see how to copy, but needed to change tabs from Library to Plan once in the Select Material window. Thank you...Barry Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 15, 2015 Share Posted October 15, 2015 Dude! That's awesome. At first i didn't see how to copy, but needed to change tabs from Library to Plan once in the Select Material window. Thank you...Barry You betcha! I thought it was a pretty sweet discovery myself. Link to comment Share on other sites More sharing options...
WendyatArtform Posted October 15, 2015 Share Posted October 15, 2015 Then when you later regret making a holy hot mess of your model by using that spray can, remember that the spray can with no material selected prior gives you a check box for "use default". Trust me, you're going to need it! Link to comment Share on other sites More sharing options...
