JeanTurcotte Posted October 3, 2015 Share Posted October 3, 2015 I created a deck framing and tried to group each part of framing. I'm able to group it and see the group in 2D but I can't see it in 3D. I turned on all the layer without any change. Have an Idea ? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 3, 2015 Share Posted October 3, 2015 Would probably be a good idea to attach the plan. Link to comment Share on other sites More sharing options...
dshall Posted October 3, 2015 Share Posted October 3, 2015 I created a deck framing and tried to group each part of framing. I'm able to group it and see the group in 2D but I can't see it in 3D. I turned on all the layer without any change. Have an Idea ? Yep, attach the plan... but viewing blocked framing has always been a problem. I do not know why, but I do know going back to 2005, if the framing was blocked, you could not se it in 3d....... solution? unblock. Link to comment Share on other sites More sharing options...
JeanTurcotte Posted October 3, 2015 Author Share Posted October 3, 2015 Sorry, here is the plan. I check the lock option and seem to be OK. Deck.plan Link to comment Share on other sites More sharing options...
dshall Posted October 3, 2015 Share Posted October 3, 2015 As I said before, blocked framing does not show in 3d. It is a nuisance. Solution, unblock framing for 3d views. Link to comment Share on other sites More sharing options...
JeanTurcotte Posted October 3, 2015 Author Share Posted October 3, 2015 It is not blocked !!! I selected all layer and unblock it. Maybe I don't really anderstand what you mean.. Link to comment Share on other sites More sharing options...
JeanTurcotte Posted October 3, 2015 Author Share Posted October 3, 2015 I anderstand now what you mean but the goal of it is to make a block to reuse it and move it easily. Another bug not resolved.... Thank's Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 3, 2015 Share Posted October 3, 2015 I anderstand now what you mean but the goal of it is to make a block to reuse it and move it easily. Another bug not resolved.... Thank's Consider just adding that block to your library then you still have it for re-use and can unblock the framing in your plan to solve the 3D view issue. Link to comment Share on other sites More sharing options...
