Room Divider & Half Walls
RobUSMC
There must be a setting that is not correct.  I opened a brand new blank plan and drew four exterior walls to make a closed room. Inside this room I drew one single straight half wall and unchecked both no room definition and no locate and  I get the same thing.  No baseboards on the wall
Been playing around with this and found a correlation. Anytime a straight half wall is not connected to another wall it does not show the base. This the case when there is a bar / sink wall in the middle of a room.  However, if I craw a wall to connect these "island" walls to a wall on the outside of the room the base appears.  I did a work around and drew a connecting wall from an perimeter wall to the half walls and made it invisible and all looks fine.  Alot to do just for baseboards
