Exterior deck
Walleye
I've got a problem that I've been wasting way too much time on.
If I draw a deck onto the existing house it shows up fine in the elevation as long as I keep the edge of deck away from the room on the left of the plan. In the first plan it is 6" away from that room. If I move it closer like in the 3rd plan, it removes the exterior wall from railing height down. I've tried moving the edge of deck all over the place and if it is within 6" of that room the same thing happens. I can extend the deck past that room and the exterior of that room stays the same, but I lose the bottom half of wall in the room on the right. The floor and ceiling heights are different in each room and I'm thinking that has something to do with it, but not sure.
Anybody have suggestions?
19' DECK FLOOR.pdf
19' DECK ELEVATION.pdf
20' DECK ELEVATION.pdf
